struct and pointer
hi,
i need a solution on how to read a struct which includes serveral types of vars with a pointer of type char.
example:
 struct test
  char a;
  int  b;
  int  c;
  char d;
struct test s_test;
char *p_test;
p_test = &s_test.a;
the compiler display error like pointer not the type of struct.
  • You need a pointer that points to the proper type, in this case, a "struct test *". In your example code, just declare the pointer correctly.
    struct test
      char a;
      int  b;
      int  c;
      char d;
    struct test s_test;
    struct test *p_test;
    Then you can reference fields of the structure with the "arrow" operator:
    p_test->a;
    If you want pointers to fields inside the structure, then you need pointers to those types (in this case "char" and "int").
    char* p_char = &s_test.a;
    The code in your example looks like it should work to me.
    If you're passed in what you know is really a pointer to a s_test, but for some reason it's described as a pointer to char, you'll need to change the type of the pointer ("cast" it). Usually, this sort of thing happens when a pointer gets passed through a routine that handles "generic" objects and treats all pointers as void* or char*.
    struct test *p_test = (struct test *)p_char;
    mychar = p_test->a;
    You can do the casts in line without declaring another variable at some cost in readability:
    mychar = ((struct test*)pchar)->a;
