Makefile help!
I have a directory full of C files, of which everyone needs compiled.
I then need to add all the resultant OBJ files to LIB file.
Is there an easy way to do this with a MAKEFILE using MS NMAKE.
The problem I am having is specifting wildcards....
TIA
Gary
  • For help with MS NMAKE, I think you need to go to a Microsoft forum! ;-)
    Any particular reason why you can't/don't want to do this in uVision?
    It'd be a doddle to just select all the files and add them all at once to a Project!
  • To build the object files you can use an inference rule, as in the following makefile snippet:
    # Source directory
    S = .
    # Output directory
    O = ./objs
    # Inference rule
    {$S}.c{$(O)}.obj:
       C51 %s $(C51_OPTS) OBJECT($(O)/%|fF.obj)
    I don't know any shortcut for linking all of the resultant object files, though.
    Shane.
