Hi. The starting address for the code compiled by the c51 compiler is always at 0000h. Is there any way to change the starting code address to 2000h? If so, can I also configure other addresses such as external address, stack pointer etc? I'm doing this because I'm currently using a trainer board. Thanks!
Take a look at http://www.keil.com/support/docs/189.htm Jon
