I need to find out how much of the available 128k flash has been used by my application. I also need to find out how much of the 32k available static RAM is being used. I believe the answers lie in the .M51 file, but am unsure of which to look at, xdata memory, code memory and data memory. Also what is to be done with the Gaps and Absolute line items? Is this information documented in any of the manuals that I could read and/or point to if necessary? Thank you.
"Is this information documented in any of the manuals" As it's the Linker map file, I'd look in the Linker Manual!! ...and don't forget the knowledgebase!
