To program the C166 mcu, 'memtool' software can be used to do the job... How to program the C51 mcu???
C51 is a language (Keil's implementation of ANSI 'C' for the 8051) - not an MCU!
ok, i m sorry than...i mean how to program 8051 mcu???what software should i use???
I'd start with the Keil C51 compiler. Then move on to the BL51 banking linker after that. What do you mean what kind of software? You write it yourself and cross-compile it for the 8051 using C51.
I believe that Memtool is a PC utility that uses the boot strap mode of the C166 processor to download and program a hex file into FLASH memory. Does a similar utility exist for 8051 based processors? I would think we would have to know the specific processor he is using to answer the question. -Walt
"I would think we would have to know the specific processor he is using to answer the question." Yes. For variants with on-chip Flash, such software is usually available from the manufacturer's website for the specific chip. For variants without on-chip Flash, the target hardware would have to be designed to support software download, and the PC software to send the download would have to be designed to match the hardware.
All of the FLASH programming utilities that I'm aware of are listed at: http://www.keil.com/flash/utilities.htm If there are others, please let me know. Jon
