I have the DK251 development kit. Is there an easy way to get Cypress EZ-USB FX2 sample code to compile in the 251 environment? I keep coming up with an error when I build saying that my "tools.ini" is bad or missing. Setup required?
No, the DK251 is for Intel/Atmel 251 architecture and the Cypress FX2 is based on 8051 architecture. You need for th Cypress FX2 and DK51 or PK51 package.
Why do I get conflicting answers from Keil support regarding this issue?? I started case # 23HHB34 and the Keil support person said that the 251 will work with the Cypress code. According to my coworkers, they think it should work with some minor adjustments. I would like a definitive technical answer regarding this issue. Steve Oakes
I started case # 23HHB34... Our call numbers are 5-digit or 6-digit numbers with no letters, so, I'm not sure where that came from but it didn't come from the Keil US office. Anyway, the C251 compiler generates code using the new 80C251 instruction set. The 80C251 has 16-bit and 32-bit registers and instructions that use them. The 8051 does not have 16-bit or 32-bit registers and does not have the enhanced 251 instructions. If you like, you can try to use the 251 compiler with an 8051 devices, but the code generated will not work. It would be the same as if you took an Intel 386 compiler and tried to use it with a 68000. Jon
