Why not printf works always.... When I tried with Keil Monotor Driver51 it did not work but was working in simulation mode. But now again when I try to debug sample code in simulated mode it does not work....
SIR I AM TESTING INTERNAL 12BIT ADC WITH LOOPING BACK INTERNAL 12 BIT DAC FOR TWO CHANNELS ON C8051F020 IN C PROGRAM BUT 4 BIT ERROR IS COMING .ANY RELATED INTERRUPT PROGRAM FOR THE ABVE IS NEEDED AT SOS REGARDS
Is the monitor using the serial port, so that it's no longer available to printf?
sir i am lookin for a 'C'program to test two channels of 12bit adc(internal)with looping back with 12bit dac(internal)using C80510F20 in 'C' PROGRAM. OR PLEASE TELL ME THE PLACE WHERE I CAN GET A C PROGRAM TO READ 8 CHANNELS OF ADC IN INTERRUPT MODE FOR ALL THE CHANNELS AT MAXIMUM SPEED.PLEASE CONSIDER THIS LETTER AS SOS AND REPLY REGARDS VSRAO EMAIL ADDRESS:vsrao_2k@yahoo.com
vs rao, Your request appears to have nothing to do with this thread - "Why not printf works always...." You are much more likely to get a response if you start a new Thread for your request! Also, avoid the use of ALL CAPITALS - this is often considered to be SHOUTING and, therefore, rude.
