Can someone check this code for me?
Hello , every body:
Hope you could give me some suggestion. I use this module to arrange my functions in a period of time, that says, when the times up, the specified routine will execute. I put the structure in the xdata, it seems that no signal was sent in time , but when I use simulator to debug, it actually could run into the corresponding function. Does any one know what's wrong in my program?
Thanks a lot!
PS. Well , I didn't post the timer routine
#define TASK_CONTROL_BLOCK_ENABLED
#define END_LIST         (const  char *)0
#define TASK_DISABLED   -1
#define TASK_ENABLED     0
#define NOT_PRESSED  0
static char idata Tmt_Thermal = 1;              //Toggle a port-bit every 2 seconds (this is an example usage)
static char idata Tmt_SetSystemVariable=5;
static char idata Tmt_DetectFanStatus=10;
static char idata Tmt_Hundredth_sec = 0;
static char idata Tmt_Tenth_sec = 10;
static char idata DetectCommand_timer = 1;
#define RESET_DETECT_TIMER 		DetectCommand_timer = 5
#define RESET_DETECTFANSTATUS 	Tmt_DetectFanStatus=10
#define RESET_SETSYSTEMVARIABLE 	Tmt_SetSystemVariable=5
#define RESET_TMT_THERMAL 			Tmt_Thermal = 1
#define RESET_TMT_TENTH_SEC 		Tmt_Tenth_sec = 10
typedef xdata struct                             // Task control Block structure
	char *task_flag;
	void (code * task_action)(void);
} TCB _at_ 0x0062 ;
static VOID HundredthSecTimer(VOID);
static VOID TenthSecTimer(VOID);
static BOOL TaskController(TCB *);
static xdata const TCB  Hundredth_sec[] =
	&(Tmt_Hundredth_sec),HundredthSecTimer,
	&(Tmt_SetSystemVariable), SetSystemThermVariable,
	//&(Tmt_DetectFanStatus), DetectFanStatus,
	END_LIST,0
static xdata const TCB Tenth_sec[] =
	&(Tmt_Tenth_sec), TenthSecTimer,
	//TODO:: put the EEprom read here
	END_LIST,0
static xdata const TCB Whole_sec[] =
	&(Tmt_Thermal),ThermalDetect,
	END_LIST,0
static BOOL TaskController(TCB *tcb_list)
	BOOL result=FAIL;
	while(tcb_list -> task_flag != END_LIST){        // while not at end of TCB list
		if(*tcb_list -> task_flag == TASK_ENABLED){   // if the timer says the task is ready to execute
			WATCHDOG_RESET_250ms;
			tcb_list -> task_action();                // execute the timed task
			result=SUCCESS;
		tcb_list++;                                  // move on to next timed element in the list
	return result;
	//return (tcb_list -> task_flag==END_LIST)?(SUCCESS):(FAIL);//<<<_1011_1::ADD_1>>>//
	TCB *ptr;
	Tmt_Hundredth_sec = 10;                             // Reset timer-variable to re-execute this routine in 1/10 second
	// Decrement all timers in Tenth_sec TCB list every 1/100 second
	for (ptr = &(Tenth_sec[0]); ptr ->task_flag != END_LIST; ptr ++){
		if (*(ptr -> task_flag) > 0){
			*(ptr -> task_flag) -= 1;
	TCB *ptr;
	//<<<_1011_1::DEL::put at outside
	//Tmt_Tenth_sec = 10;                             // Reset timer-variable to re-execute this routine in 1 second
	//_1>>>
	// Decrement all whole_sec timers every 1/10 second
	for (ptr = &(Whole_sec[0]); ptr ->task_flag != END_LIST; ptr ++){
void  TaskEnable(void)
	TCB *ptr;
	for (ptr = &(Hundredth_sec[0]); ptr ->task_flag != END_LIST; ptr ++)
VOID TaskControl(VOID)
	if(SUCCESS==TaskController(Hundredth_sec)){
		(Tmt_SetSystemVariable==0)?RESET_SETSYSTEMVARIABLE:1;
		(Tmt_DetectFanStatus==0)?RESET_DETECTFANSTATUS:1;
		RESET_DETECT_TIMER;
	if(SUCCESS==TaskController(Tenth_sec)){
		(Tmt_Tenth_sec==0)?RESET_TMT_TENTH_SEC:1;
	if(SUCCESS==TaskController(Whole_sec)){
		RESET_TMT_THERMAL;
void main(void)
    for(;;){
        TaskControl();
