passing ports to a function
I have a program in which I have to manipulate 4 LEDs. I have a function that is designed to find out exactlywhat I need to do to each LED ie flash, fade, dim, etc but in order to save on code space I would like to send the program the LED by reference. For instance on of my functions looks like the following:
void switchon(&sbit LED, bit turnon)
  if(turnon)
    LED=ON;
  if(!turnon)
    LED=OFF;
where LED is the LED I am currently wanted to manipulate. I keep getting errors with this code. I have even tried just passing the LED by value and as a bit. Nothing seems to work. Is this valid?
Justin Moses
