library code
I want to realize a remote upgrade, but in order to read the new code, i need a library (in LIB_CODE segment) of the compiler. The fact is that this library change when we change the code, so i can not put it on a permanent place. I can not put it in the upgradable space, because i will erase it when i will need it.
1) Am I correct?
2) Does it exist an option of the compiler in order to put all the funcyion in the LIB_CODE part?
3) Do you have an idea to solve my problem?
Thank you
Kaoru
