Hello, How do I set the linker to use a different startup file instead of the default Startup.A51? Regards, KC
Hi Ken, You can simply put your modified startup.a51 into your project and then compile it. Best regard, Frank
Why not take total control and link in a commandline instead. That gives you total freedom and you do not have to do what the designers (most often wrongly) assume is "always the case". I my current project I have two builds, one for debug and one for production, startup is different in those two cases, I could not live with a mandatory name of startup. Erik
