Cygnal F310 -- Can't connect to hardware
I am developing an application for the Cygnal C8051F310 variant. As of 7.02b, there is an entry in the chip database for it. I have downloaded the uVision2 debugging files from Cygnal (release notes state that it supports my chip), but cannot connect and upload a program to a hardware target (Cygnal 310/11 development board). If I use Cygnal's IDE, I can connect, upload, and debug a sample program (with disassembly view).
I purchased the DK51 toolset thinking it would be easier to develop within the uVision environment. Does anyone have a solution to this problem? I'd like to use the uVision environment - after all, I paid an extra $500 for it.
Setup:
* Cygnal EC2 serial to JTAG/C2 adapter
* Cygnal C8051F310/311 development board
* F310 uses 2-wire C2 interface for debugging
* uVision 2 V2.32 and C51 V7.02b
Any help would be greatly appreciated.
-Tom
  • Sorry for the double-post. Mouse slipped...
  • I got this from the release notes from the latest Cygnal uVision2 Driver.
    KNOWN ISSUES AND LIMITATIONS
    	1.) Only F00X, F01X, F2XX, F02X & F30X7 devices are
    	    supported by this version.
    It looks like the 31x parts are not yet supported. However, I know that Cygnal adds uVision2 support for new devices quickly.
    I seem to recall seeing a thread about this on their discussion forum that said when support would be available, but I couldn't find it.
    It may be worth a call to them to see when updated drivers will be available.
    Jon
  • Hmm. These are excerpts from the rel_notes.txt file that came with the V1.24 uVision driver:
    "Version 1.2
    Support has been added for F02X & F3XX devices.
    Flash programming has been enhanced. The download algorithm
    has been enhanced to improve speed. When flash is being
    programmed, a status message and progress indication has been
    added. DPTR value is now correctly displayed. Modifications
    to the code space are now updated during step operations.
    A progress dialog was added when a firmware upgrade is
    performed.
    Also:
    "KNOWN ISSUES AND LIMITATIONS
    1.) Only F00X, F01X, F2XX, F02X & F3XX devices are
    I'll bet you're right. I just wish they had been more specific. I'll contact Cygnal and find out for sure. Thanks for the feedback.
    -Tom
  • FYI, the release notes I quoted are from the 1.26 release.
    Jon
  • I have the same situation here with Cygnal F020 after upgrade to v 7.02.
    The project properties Debug page refers to dialog dll TCYG.DLL which can not be found anywhere.
    All worked fine with v 7.01 - I don't remember what was the dialog dll name there.
  • More specifically -
    in my old (working) .UV2 file for v 7.01, there is the following option line:
    OPTDL (S8051.DLL)()(DP51.DLL)(-p51F00)(S8051.DLL)()(TP51.DLL)(-p51F00)
    OPTDBG 49150,-1,()()()()()()()()()() (c:\keil\c51\bin\CYGC8051F.DLL)()()()
    After upgrade to 7.02c and reinstalling Cygnal plug-in for uVision except of uv2.cdb, these lines look thusly:
    OPTDL (S8051.DLL)()(DCYG.DLL)(-pCYGF020)(S8051.DLL)()(TCYG.DLL)(-pCYGF020)
    OPTDBG 1534,-1,()()()()()()()()()() (BIN\CYGC8051F.DLL)()()()
    Note the TCYG.DLL - it is missing on the disk.
    Regards,
    -- Pavel
