Hello, May I know if the code as shown below works? -------------------------------------------- #pragma src void main(void){ #pragma asm myMacro MACRO MOV R1, #01 MOV R2, #02 MOV R3, #03 ENDM #pragma endasm #pragma asm #define myMacroFunc() myMacro #pragma endasm #pragma asm myMacroFunc() #pragma endasm } --------------------------------------------- regards,
The short answer is: no. The slightly long answer is: as you are a beginner, I think you should start somewhere else! More helpfully: what exactly is it that you want to achieve? In the meantime: welcome to the forum and good luck. BTW: this is a professional forum, please use your real name.
