Question about the µVision Simulation-Results / log
i have a Question about the µVision Simulation-Results.
We use µVision for Simulation of an 8051 Microcontroller.
Is there any possibility to write the Simulation-Results in a txt-File (or another type of file)?
I am using the Version µVision/51 Ver 1.32 and the new µVision 2 (2.31, eval).
With friendly greetings from Germany,
MS
  • As I've mentioned frequently before, uVision's support for printing or saving any of the useful information displayed on the screen is particularly poor. :-(
    You have to cast your mind back to the bad old days of MS-DOS, command lines, etc:
    1. Turn on logging of the debugger output to a file (use the LOG command);
    2. Use the PA command to display Performance Analyser results;
    3. Close the logfile;
    4. Open the logfile in your favourite text editor.
    Simple, eh?! :-(
