I am doing a project and want to use both the serial port at 2400bps and timer 0 for timing ticking. for the serial: my setting is that: TMOD=0x20; TH1=-13; TL1=1; SCON=0x50; for the timer: TMOD=0x01; TH0=(65536-5000)/256; TL0=(65536-5000)%256; IE=0x82; TR0=1; the problem is i find the TMOD need to set in both code. How can i make two timer work seperately and work without collide? I find my system not work and the timer0 suddenly reset. pls help
moreover, i have recheck the program, i found the when i put the data into the serial buuffer SBUF=data; the timer was stopped pls help
Welcome to the C language. If you would like to set the upper nybble of TMOD without affecting the lower nybble of TMOD try:
TMOD &= 0x0F; TMOD |= 0x20;
TMOD = TMOD & 0x0F | 0x20;
#define WRITE_TMOD_T1(nybble) do { TMOD = TMOD & 0x0F | (nybble) << 4 } while (0)
#define WRITE_TMOD_T0(nybble) do { TMOD = TMOD & 0xF0 | (nybble) } while (0)
WRITE_TMOD_T1(2); WRITE_TMOD_T0(1);
