How to Erase/Program External AM29F040 Flash on MCB167-NET
I am in need of some help.
I have a MCB167-NET board (configured as 16 bit addressing), which contains a 2xFlash modules from AMD (AM29F040B).
I am writing my own Bootloader to copy my program to external RAM, erase and then the program it to the flash.
The following code on chip erase (with AMD ERASE algorithm) works on 8-bit non-multiplexing mode. However, how do I get it modified to erase and program the FLASH in 16 bit addressing??
ERASE_FLASH:    MOV		DPP2,#0001H   ;write 0xAA to [0x5555]
    		MOV		R12,#09555H
    		MOVB	RL1,#00AAH
    	 	MOV		[R12], RL1
    		MOV		DPP2,#0000H   ;write 0x55 to [0x2AAA]
    		MOV		R12,#0AAAAH
    		MOVB	RL1,#0055H
    		MOV		[R12], RL1
    		MOV		DPP2,#0001H   ;write 0x80 to [0x5555]
    		MOV		R12,#09555H
    		MOVB	RL1,#0080H
    		MOV		[R12], RL1
	        MOV		R12,#09555H
    		MOVB	RL1,#00AAH
	   	MOV		[R12], RL1
    		MOV		R12,#0AAAAH
    		MOVB	RL1,#0055H
    		MOV		[R12], RL1
    		MOV		DPP2,#0001H   ;write 0x10 to [0x2AAA]
    		MOV		R12,#09555H
    		MOVB	RL1,#0010H
    		MOV		[R12], RL1
    		MOV		R13,#09555H
    		MOVB	RL2,#80H              ;wait till erase is ok by polling
    		CALLR	ERASE_POLL
    	   	MOV		R4,#ERASE_OK
Please help me.
  • I did write something to program AMD Flash once, but that was several years ago, and using an ARM, and for a Client which no longer exists.
    Anyway, I found all the info I needed in the AMD datasheets and the application notes & example code on their website.
    Dunno if it's still all there, though...
  • Thanks for the information.
    The problem encountered is AMD is an 8-bit device while C167 is configured as 16 bit. And I am using 2x AMD, for higher/lower byte memory.
    To program the flash, I need to perform some unlock cycles. For instance, AMD requires the first cycle to write 0x55 to [0x2AAA] of the chip. Does that mean, I will need to write to address [0x2AAA<<1] on lower byte AMD memory and address [0x2AAA<<1 + 1] on higher byte AMD memory?
    Anybody has the assembly code to perform this task using C167 chip?
