I see that Keil is supporting the RCS version control system. Has anyone had any sucess in integrating Microsoft SourceSafe? If so, how?
We provide a template that should help get you started. What problems are you having? Jon
Ok. I guess I have been at this so long that I don't read the documentation any more. I do have a request. In the future can you keep the data base path in the UV2 file. I have many data bases and it would be a whole lot easier if SVCSDB is an item in the file.
