Would you please tell me where I could find some information about mon166.dll v2.31 (parametres and exported functions). I intend to write a program in the LabView system, with which to be able to program a processor C167 in the Windows2000 system. So far I have used mon166.exe v2.23 at a DOS PC , but the program in question does not work (respond) in the DOS window of Windows 2000 (error - "Target system not connected")
Is there a specific reason you want to use the monitor to program the device? Would a FLASH programming utility work for your application? If so, take a look at http://www.keil.com/flash/utilities.htm for a bunch of C16x/ST10 FLASH programming utilities. Jon
I need an RS232-terminal after program download for keyboard input. What is the alternative to MON166.EXE (DOS) "Terminal Mode"? How to use mon166.dll just for downloading a program from my windows terminal application?
