Hello, I'm trying to create my own library file and include it into my project 1)I've written two function in separate files abc.A51 and xyz.A51 2)These files contain only 1 functions each abc() and xyz() respectively 2)Then I created a project called "MyLib" 3)Then I included both abc.A51 and xyz.A51 in the project 4)Then I compiled it to a "library" 5)So I obtained the library file MyLib.lib and also abc.obj, xyz.obj 6)Now I create another project "MyProj" and a main.c file My question is how do I include the library file MyLib.lib into this main.c file in the new project? Note that originally my function was in assembly... so i didnt have header file for function prototype. Also, If my main.c file uses only one of the functions ( example abc() ) will my final object file take less space compared to if i used both the functions ( abc() and xyz() ) Thank You
