I build a C167-project using a make utility. In one step, I let the CA166(V4.2) compile a file with option PPO (pre processor only). The compiler does that correctly, but returns a DOS-warning level, which causes my "make" to stop. It does not print a warning text. Is there a way to force the compiler not to do so?
