what are error 25, 53, 122 all about. i keep getting them in odd places and for stuff i am pretty sure is correct. (i know its correct for c++!) like the while one loop line has sveral eerorrs on it and all we did was change thew semicolon to an open braces. thanks anton
"like the while one loop line has sveral eerorrs on it and all we did was change thew semicolon to an open braces." Ah yes, famous last words: "all I did was..." Please post the real code, so that we can see what you've really done (not fogetting those pre and /pre tags)
all the errors went away when i combined my two variable decelerations for uword. are you not allowed to declare a variable of a type and then go and declare a DIFFERENT variable of the same type?
It depends. Where is the code? We can't read your mind :-))
"all the errors went away when i combined my two variable decelerations" You must define your variables at the same speed. ;-)
