Hi All,, Its a way off topic question from the list, with the hope that ppl here would not take it offensive, I appologize in advance. I am writing a C program for my computer . The system() command in C can used to run OS commands at runtime from the program. What i am looking for is some way by which i can convert a whole directory (and its subdirectories) into a single file. If anyone has done this before or has any idea how to go about doing this , then i would be happy to know that. One obvious way to do that is use winzip to make a .zip file of a directory. But i dont know how to run a windows application from C program. Any suggestion would be great. Thankzz && Bye -Rocknmoon
shell? spawn?
You can download a command line thing for winzip at the winzip site. I am using this for years now. I have written a dos batch file that queries if I want to archive e.g. all my C51 stuff or my project directory etc. I usually run it at the end of the day and this way, everything I have changed while the day is updated in or added to the zip-file that I use for that directories. Then I copy it to the file server. This way, I have 2 copied of my files and it is also pretty simple to burn it on CD-ROM. The file for the commandline option of winzip is called wzbetacl.exe.
The file Archive Attribute is very useful for this; it can be used with WinZip, and the original command-line PKZIP, and XCOPY, etc, etc The command
XCOPY /s /m *.* dest
ATTRIB -a *.bak /s
Thanks for all the explanations. Andrew & Sven would you be kind enough to send me your sample batch files ?? Thanks in advance. rocknmoon@yahoo.com
