mon51 with Atmel T89C51CC01
I am trying to use mon51 with a custom board based on Atmel-WM T89C51CC01 (32k Neumann RAM at 0x8000). uV2 finds the connection with the monitor and downloads my code without any error messages. After "$= 0x8000" I see my code (0x8000 LJMP STARTUP1(C:8448)). But "g, main" simply does not work, the program stucks at 0x8000. After a single step it performs the jump, but after the next one(0x8448 MOV R0, #0x7f) I find myself at 0x8000 again.
What I already tried:
(1) In T89C51CC01 one should clear ENBOOT in AUXR1 to disable FM1 from 0xf800-0xffff. So I installed mon51 to 0xe000 (install.bat 2 e0 0).
(2) I followed the steps in APP. 152
(3) I performed the RAM test recommended by Keil (MON51: TESTING VON NEUMANN MEMORY AREAS). It works fine from 0x8000 to 0xf800.
Does anyone has a board with the same controller and memory configuration? It would be good to see and try out a program that already worked on a real HW.
Thanks for any help,
Gergely
  • I've had this problem before. It is almost always an indication that the monitor data area is not von Neumann memory. You can easily test this.
    Take a look at the following KB article.
    http://www.keil.com/support/docs/2104.htm
    Sometimes getting the monitor configured is a pain in the @$$, but it has been my experience that it is a problem with the memory areas not being von Neumann.
    Jon
  • I have done it already, it was (3).
    From 0x8000 till 0xf800 everithing is all right (above comes FM2). That is why I installed mon51 at 0xe000.
    Thanks anyway. Don't you happen to have a working "Hello World" uV/uV2 project for mon51 target :)?
    Gergely
  • Don't you happen to have a working "Hello World" uV/uV2 project for mon51 target :)?
    I thought we did butg I didn't find it. Anyway, it's pretty simple. Just remove the code that initializes the serial port.
    But try something even simpler. For example:
    void main (void)
    while (1)
      P1 ^= 0xFF;
    This toggles the bits of P1.
    Jon
  • Not really the program itself is important, but its configuration in uV/uV2. But unfortunately the problem is bigger than that, because without any code only with the default (garbage) memory content the result is the same. So I set PC to 0x9000 (0x9000 00 NOP), "Step Into", and I am at 0x8000 again :((((. I suspect that you are right Jon with the monitor data area. But what can I do if the Keil memtest works, and I also wrote some code to detect any faulty memory locations (stuck bits or mirroring)?
