//test code Keil6.23 1 unsigned int code tbl[10][2]={ 2 { 80, 1986},{ 600, 2630},{ 1390, 3584},{ 2180, 4509},{ 2960, 5396}, 3 { 3730, 6245},{ 4500, 7069},{ 5260, 7858},{ 6020, 8623},{ 6200, 8800} 4 }; 5 void main() 6 { 7 1 unsigned int code *Table; 8 1 unsigned int d1,d2,d3,d4; 9 1 unsigned char DataOff; 10 1 11 1 DataOff=3; 12 1 Table=tbl[0]; 13 1 14 1 d3=*Table; 15 1 d4=*(Table+2); 16 1 Table=Table+2-DataOff; 17 1 // Table=Table-DataOff+2; 18 1 d1=*Table; 19 1 d2=*(Table+2); 20 1 } C51 COMPILER V6.23a MAIN } ; FUNCTION main (BEGIN) ; SOURCE LINE # 5 ; SOURCE LINE # 6 ; SOURCE LINE # 11 ;---- Variable 'DataOff' assigned to Register 'R7' ---- 0000 7F03 MOV R7,#03H ; SOURCE LINE # 12 0002 7C00 R MOV R4,#HIGH tbl 0004 7D00 R MOV R5,#LOW tbl ;---- Variable 'Table' assigned to Register 'R4/R5' ---- ; SOURCE LINE # 14 0006 8D82 MOV DPL,R5 0008 8C83 MOV DPH,R4 000A E4 CLR A 000B 93 MOVC A,@A+DPTR 000C F500 R MOV d3,A 000E 7401 MOV A,#01H 0010 93 MOVC A,@A+DPTR 0011 F500 R MOV d3+01H,A ; SOURCE LINE # 15 0013 7404 MOV A,#04H 0015 93 MOVC A,@A+DPTR 0016 F500 R MOV d4,A 0018 7405 MOV A,#05H 001A 93 MOVC A,@A+DPTR 001B F500 R MOV d4+01H,A ; SOURCE LINE # 16 001D EF MOV A,R7 001E 75F002 MOV B,#02H 0021 A4 MUL AB 0022 FF MOV R7,A 0023 ED MOV A,R5 0024 2404 ADD A,#04H 0026 FD MOV R5,A 0027 E4 CLR A 0028 3C ADDC A,R4 0029 CD XCH A,R5 002A C3 CLR C 002B 9F SUBB A,R7 002C FD MOV R5,A 002D 95F0 SUBB A,B ; SOURCE LINE # 18 002F 8D82 MOV DPL,R5 0031 F583 MOV DPH,A ;************************************* ;---- Variable 'Table' assigned to Register 'R4/R5' ----but here A!=R4,A=R5-B ;************************************* 0033 E4 CLR A 0034 93 MOVC A,@A+DPTR 0035 F500 R MOV d1,A 0037 7401 MOV A,#01H 0039 93 MOVC A,@A+DPTR 003A F500 R MOV d1+01H,A ; SOURCE LINE # 19 003C 7404 MOV A,#04H 003E 93 MOVC A,@A+DPTR 003F F500 R MOV d2,A 0041 7405 MOV A,#05H 0043 93 MOVC A,@A+DPTR 0044 F500 R MOV d2+01H,A ; SOURCE LINE # 20 0046 22 RET /***************************** if line 16 write as Line 17 then compiled OK ; SOURCE LINE # 17 001D EF MOV A,R7 001E 75F002 MOV B,#02H 0021 A4 MUL AB 0022 FF MOV R7,A 0023 C3 CLR C 0024 ED MOV A,R5 0025 9F SUBB A,R7 0026 FF MOV R7,A 0027 EC MOV A,R4 0028 95F0 SUBB A,B 002A CF XCH A,R7 002B 2404 ADD A,#04H 002D FD MOV R5,A 002E E4 CLR A 002F 3F ADDC A,R7
Please re-post that code, using the <pre> and </pre> tags - like it says in the instructions! Then your layout will be preserved, and we'll be able to read your code! Don't use TABs!
