RS232 communication via serial I/O
I got a RS232 Serial routine from this site. But when I tried on my actual
hardware it did not work. I work OK
using Dscope simulator. Could somebody
be kindly to take a quick look at the code to see if why/how it dit not
work on the actual hardware. My hardware uses a 14.318MHX oscillator, and I want to config the protocol for
9600 baudrate.
Here is the code:
SIO.C: Serial Communication Routines.
#include <reg52a.h>
#include <string.h>
#include "sio.h"
void main (void)
com_initialize (); /* initialize interrupt driven serial I/O */
com_baudrate (9600); /* setup for 9600 baud */
printf ("Interrupt-driver Serial I/O Example\r\n\r\n");
while (1)
unsigned char c;
printf ("Press a key from the keyboard .\r\n");
c = getchar (); //store pressed character
printf ("\r\nYou pressed '%c'.\r\n\r\n", c); //print out Character
} //end Main
char _getkey (void)
int k;
do
k = com_getchar ();
while (k == -1);
return ((unsigned char) k);
char putchar (char c)
volatile unsigned int i;
while (com_putchar (c) != 0)
for (i=0; i<1000; i++)
/*** DO NOTHING ***/
return (c);
/////////// end main() //////
#define TBUF_SIZE 256
#define RBUF_SIZE 256
#define XTAL 14318000 //XTAL frequency
static xdata unsigned char tbuf [TBUF_SIZE];
static xdata unsigned char rbuf [RBUF_SIZE];
static xdata unsigned char t_in = 0;
static xdata unsigned char t_out = 0;
static xdata unsigned char t_disabled = 0;
static xdata unsigned char r_in = 0;
static xdata unsigned char r_out = 0;
static void com_isr (void) interrupt 4 using 2
Received data interrupt.
if (RI != 0)
RI = 0;
if ((r_in + 1) != r_out)
rbuf [r_in++] = SBUF;
Transmitted data interrupt.
if (TI != 0)
TI = 0;
if (t_in != t_out)
SBUF = tbuf [t_out++];
else
t_disabled = 1;
void com_initialize (void)
Setup TIMER1 to generate the proper baud rate.
Clear com buffer indexes.
EA = 0; /* Disable Interrupts */
t_in = 0;
t_out = 0;
t_disabled = 1;
r_in = 0;
r_out = 0;
Setup serial port registers.
SM0 = 0; SM1 = 1; /* serial port MODE 1 */
SM2 = 0;
REN = 1; /* enable serial receiver */
TI = 0; /* clear transmit interrupt */
RI = 0; /* clear receiver interrupt */
ES = 1; /* enable serial interrupts */
PS = 0; /* set serial interrupts to low priority */
EA = 1; /* Enable Interrupts */
void com_baudrate ( unsigned baudrate)
Clear transmit interrupt and buffer.
t_in = 0; /* empty transmit buffer */
t_out = 0;
t_disabled = 1; /* disable transmitter */
Set timer 1 up as a baud rate generator.
TR1 = 0; /* stop timer 1 */
ET1 = 0; /* disable timer 1 interrupt */
PCON |= 0x80; /* 0x80=SMOD: set serial baudrate doubler */
TMOD &= ~0xF0; /* clear timer 1 mode bits */
TMOD |= 0x20; /* put timer 1 into MODE 2 */
TH1 = (unsigned char) (256 - (XTAL / (16L * 12L * baudrate)));
TR1 = 1; /* start timer 1 */
char com_putchar (
unsigned char c)
If the buffer is full, return an error value.
if ((TBUF_SIZE - com_tbuflen ()) <= 2)
return (-1);
Add the data to the transmit buffer. If the
transmit interrupt is disabled, then enable it.
tbuf [t_in++] = c;
if (t_disabled) /* if transmitter is disabled */
t_disabled = 0;
TI = 1; /* enable it */
return (0);
int com_getchar (void)
int c;
if (com_rbuflen () == 0)
return (-1);
c = rbuf [r_out++];
return (c);
unsigned char com_rbuflen (void)
return (r_in - r_out);
unsigned char com_tbuflen (void)
return (t_in - t_out);
