how can i change the HEX file to TSK file?
Rather than start a new thread, why not continue in the one you've already started? http://www.keil.com/forum/docs/thread1648.asp What is the definition of this "TSK" file? If it is the same as the absolute image generated by the Keil linker, then just tell the linker to call its output file "output.TSK" (by default, it's just "output" - no extension) Are you really using a simulator, or an emulator? (see the earlier thread)
thx for your reply som much! it is a emulator www.cpu.com.tw/.../1213-1.jpg as i am a new user of 8051, therefore i may ask some stupid question. pls help me! any sorry to bother you
You need to determine what is the definition of this "TSK" file? What does the manual for your emulator say?
