Archimedes Compatibility
I have some code that was developed using the Archimedes Complier. I'm thinking about purchasing the DK51 complier. Has anyone had any expierence on what difficulties I may face?
  • If the Archimedes Compiler is a relatively recent version, let's say V6 or higher, it is a "rebranded" Keil version and you should have few, if any, difficulties.
    When Archimedes switched to Keil, I'm not sure, but I believe some earlier versions were a rebranded IAR compiler that had slightly different syntax for expressing the '51-isms like SFR's, bits, mem spaces, intrinsic functions, etc. If it's an IAR version you're dealing with, it will be more work, but not a real big deal. I suspect a number of the translation issues could be handled by some preprocessor macros.
  • "I suspect a number of the translation issues could be handled by some preprocessor macros."
    It's a good idea to always encapsulate all compiler-specifics in preprocessor macros - then changing compilers is just a matter of suitably redefining the macros.
