I am using an Infinion C161CS with 2UARTS\SSC\2CAN. In the peripheral window of the debugger there are missing some on-chip peripharals like ASC1 SSC both CAN ports. If I am simulating the Target they are displayed and accessible. In both cases I use the Dialog dlls configured in the Target Options/Debug window with -p161CS parameter. There are two different DialogDLLs D167.dll and T167.dll. It seems to me that the Dialog DLL T167.dll doesn't show this peripherals. Does anybody know how I can fix this and access these peripherals on my target.
The Target Display DLL was only implemented for the C167CR. However in the next upcoming release V4.23 this DLL is fully implemented and supports the same devices as available under simulation. If you need this DLL urgent, please send email to: support.intl@keil.com.
