I am not able to configure target in keil microversion 2 using mon51 is a basic doubt only i am alone any one pls help i only use the simulator s.velan
In the Toolbar, choose Projet -> New Project... Enter a name of your project and choose your target
Thank you But the problem is the hardware targret i would like to use the Keil mon51 to configure the target board. pls help me S.Velan.
You must use µv2 v2.20 to have full target support with MON51. In previous version target support was only with simulator not with MON51.
Thank you sir i will get vertion v2.20 and procede thank you. you helped me save time or else i will be wasting time on it.
