Hi we are facing the problem in loading code memory into the target . we have done all the jumper setting given in ashling manual." embedded development systems " when we select target option in the mapping window we get error message "Code memory is not accessible ".( code memory 0000 to oxFFFF). Qn. 1) Is any other option to load the code to target with target option in mapping window ? Qn.2) how to load the code if code area is greater than 64 K . ( we are using Philips PCD50913/23 processors.)? . if we use banking then only one BANK0 is allowed (ie 49K to 64 ) .above that we are not able to load the code . thanking you Girish Kumar I K
