Yes, the real problem is, I would like to write an easy to switch, multilingual menu. And I imagine, an array like that should work. But there seems to be some brain blocking in 1. How to define and initialize and 2. How to access finally the wanted string. Ok, ommitting the string definition, the array of pointers to strings is easy. char *lang[] = {string1,string2,...}; lang should be the pointer to this array. If I define an array of such pointers, is it char *langset[] = {lang1,lang2,...}; or void *langset[] = {lang1,lang2,...}; and how to access print(langset[langchoice][stringchoice]);??? Or am I just thinking too much and there is a much easier solution to the prob? Any ideas appreciated
This is just a C question, try this:
#include <stdio.h> #define NUM_OPTS 5 int main(void) { int idx; const char * const pMenuEnglish[NUM_OPTS] = { "1. Option A", "2. Option B", "3. Option C", "4. Option D", "Escape" }; /* Force other menus to have same entries as English */ const char * const pMenuFrench[NUM_OPTS] = { "1. Optionne A", "2. Optionne B", "3. Optionne C", "4. Optionne D", "Escapez" }; /* Language independent pointer */ const char * const *pMenu; /* Choose language 1 */ pMenu = pMenuEnglish; printf("\nMenu\n"); for (idx = 0; idx < NUM_OPTS; ++idx) { printf(" %s\n", pMenu[idx]); } /* Choose language 2 */ pMenu = pMenuFrench; printf("\nMenu\n"); for (idx = 0; idx < NUM_OPTS; ++idx) { printf(" %s\n", pMenu[idx]); } return 0; }
Yes, but! In my application, I did an independant command interpreter, single char commands. And I feed him with a structure, containing all needed information to do his job.
struct Menu{ // String with allowed chars char code *commands; // count of commands unsigned char count; // pointer to the array with // strings to display char code **display; // count of strings unsigned char lines; // pointer to an array with // pointers to the needed functions void (code **dest)(void); };
// dpstring serves a 4x20 char display dpstring(col, row, (const char code *)Menu->display[select]);
dpstring(col,row,(const char code *)Menu->display[lang][select]);
// german menu code const char code *MenuG[]={ "Punkt eins", "Punkt zwei", "Punkt drei" }; // english menu code const char code *MenuE[]={ "point one", "point two", "point three" }; // independant menu pointer // something like code const char code *Menu[]={ MenuG, MenuE }; // and then struct Menu root={ "123\x1b", // command chars 3, Menu, // strings 2, Rootfunctions // functions };
lang = deutsch; // or lang = english;
Your variable Menu has a bad declaration. Try:
#include <stdio.h> #include <reg52.h> typedef char code* MenuItem; typedef MenuItem code* Menu; typedef Menu code* Menus; typedef struct MenuCtrl_Tag{ char code* commands; unsigned char count; Menus menus; unsigned char lines; void (code **dest)(void); } MenuCtrl; // german menu code MenuItem menuG[]={ "Punkt eins", "Punkt zwei", "Punkt drei" }; // english menu code MenuItem menuE[]={ "point one", "point two", "point three" }; // independant menu pointer // something like code Menu menusGE[]={ &menuG, &menuE }; code MenuCtrl root={ "123\x1b", // command chars 3, &menusGE, // strings 2, NULL // functions for now }; void main() { TI = 1; //to make printf works in debugger printf( "%s\n", root.menus[1][1] ); //should be "point two" while( 1 ) ; } <\pre>
