Hi,everyone! A problem here:The cygnal's MCU has two serial ports,so "printf" function must be reworked.But I don't know how to do it. Give me a hand! Thanks a lot!
You can rework putchar to use both ports. There is also sprintf which knows nothing about ports. Regards, - Mike
See my UART driver example at http://www.embeddedfw.com for how to do this. Basically, you just re-define putchar() which Keil's printf() calls. When ever you override a library function, the linker will take your function and not the library version. - Mark
Note that the printf library function is huge - it has to be to support all those formats & options! I think you'll find that the classic "Hello, world" first 'C' program will take up nearly all the 2K codespace limit of the C51 Eval version! For embedded stuff, it's usually better to write your own routines, implementing only those specific features which are actually needed in your application. You could then include a parameter which specifies which serial port to use. I did this, and included a "null" value for the port - this makes it easy, for example, to turn debug output on & off without obfuscating your mainline code with loads of "if( debug )" clauses.
Instead of if (debug) clauses, try this:
#ifdef DBG # define debug #else # define debug while (0) #endif // Usage: single line debug printf("Got here\n"); // Usage: multiple line debug { g_errno = 12; printf("Got error, %d\n", g_errno); }
You may check this info.: http://www.keil.com/support/docs/788.htm
Mark, Yes, of course, that gives you compile-time control to produce an image which either has debug output or doesn't. I needed the ability to enable/disable the debug output at run-time In fact, I did also use conditional-compilation so that I could build either a completely "clean" (debug-free) image, or one with the runtime-controllable debug
Hi,My friends. I will have a try! Thank you very much!
This is a start on this problem:
//----------------------------------------------- #include "stdio.h" volatile unsigned char sio_selector = 0; //----------------------------------------------- char putchar (char c) { if (sio_selector == 0) { while (!TI_0); /* wait until transmitter ready */ TI_0 = 0; SBUF0 = c; /* output character */ } else { while (!TI_1); /* wait until transmitter ready */ TI_1 = 0; SBUF1 = c; /* output character */ } return (c); } //----------------------------------------------- char _getkey (void) { char c; if (sio_selector == 0) { while (!RI_0); /* wait for a character */ c = SBUF0; RI_0 = 0; /* clear receive interrupt bit */ } else { while (!RI_1); /* wait for a character */ c = SBUF1; RI_1 = 0; /* clear receive interrupt bit */ } return (c); } //----------------------------------------------- void main (void) { //Initialize SIO0 //Initialize SIO1 while (1) { sio_selector = 0; printf ("Serial Port 0\r\n"); sio_selector = 1; printf ("Serial Port 1\r\n"); } } //-----------------------------------------------
