OMF File format
I am building a little utility to see into library files. I am using the MCS-51 object module format specification V5.0 referenced in this web.
I get some record types id non-described in that reference: 0x20, 0x22, 0x24, 0x70 and 0x72.
Is the V5.0 obsolete ?
Are they custom extensions ?
Am i doing something wrong ?
Thanks in advance
Javier
  • For 0x7x records you can get the description in the omf166.pdf available here.
    0x20 0x21 and 0x22 records are types which I am searching too for infos.
    All I know is that this seem to be debug records (0x22) and 0x20 contains function params ??
    if you find out anything please let me
    know.
    thzepf@yahoo.com
    cheers Thomas
