I bought PC-LINT and its a great tool, I'm getting error 129 message for the include files wherever it encounters sbit or srf, any suggestion how to remove this error?
Have you read the stuff in the uVision2 Getting Started manual? (gs51.pdf)
First thing i read was Running Pc-Lint in getting started, how else did i manage to run it. I also read lint manual (which says only 1 word about keil c51) I suppressed error 129 in library files (used -elib(129) and problem solved but don't know if this is the right thing to do. Wish someone who used pc lint on keil before to answer to speed my learning curve. thanx
Problem solved, Just downloaded upgraded version of pc-lint and worked liked magic, it must have been a bug
In the version I purchased a few years ago, there was a modified .LNT file which configured the LINT so that it would handle objects such as sbit and sfr without generating errors. Try looking in the LINT directory and see if theye are still there. You can include them in the options list and they should simplify the task.
