I'm new to keil and my boss forced me to use atmel 89S8252 so plz bare with me i have a few questions : 1. when a higher level priority interrupt interrupts lower level interrupt, do i lose the old interrupt or does it come back to it after higher level priority interrupt returns ? 2.Can I declare eeprom variable in keil c or do i have to do it in low level (i.e access the registers)?
I'm new to keil and my boss forced me to use atmel 89S8252 so plz bare with me i have a few questions : Forced? Consider yourself lucky. At least it's not a PIC :-) 1. when a higher level priority interrupt interrupts lower level interrupt, do i lose the old interrupt or does it come back to it after higher level priority interrupt returns ? It comes back to the interrupted ISR. 2.Can I declare eeprom variable in keil c or do i have to do it in low level (i.e access the registers)? C compilers don't know about EEPROM or RAM or serial EEROM. If it's memory mapped, then declare it _at_ the location and be sure it is not modified by the startup.a51. So you need to add a non-standard C extension to your C code and ensure the C run-time knows about it. - Mark
can u give me example on no. 2 plz ?
Ok i got it, thanx alot
