I cannot get PWM signal in P7.1..pls help me MY Program is .. #include <stdio.h> /* standard I/O .h-file */ #include <reg167.h> /* special function register 80C167 */ #include <math.h> a int i; double La[200],Lb[200]; unsigned int sdata deltaKLa[400]; unsigned int sdata deltaKLb[400]; int sdata period_reg; int sdata PECC7_init; int sdata PECC6_init; void PWM (void); void pulse (void); void delay (int); void CC_PEC_init(void); void PWM_PEC_init(void); void PWM_Init(void); /****************/ /* main program */ /****************/ void main (void) { /* execution starts here */ /* initialize the serial interface */ #ifndef MCB167 /* do not initialize if you use Monitor-166 */ P3 |= 0x0400; /* SET PORT 3.10 OUTPUT LATCH (TXD) */ DP3 |= 0x0400; /* SET PORT 3.10 DIRECTION CONTROL (TXD OUTPUT) */ DP3 &= 0xF7FF; /* RESET PORT 3.11 DIRECTION CONTROL (RXD INPUT) */ S0TIC = 0x80; /* SET TRANSMIT INTERRUPT FLAG */ S0RIC = 0x00; /* DELETE RECEIVE INTERRUPT FLAG */ S0BG = 0x40; /* SET BAUDRATE TO 9600 BAUD */ S0CON = 0x8011; /* SET SERIAL MODE */ IEN = 1; /*Globally enable interrut request */ #endif while (1) { /* An embedded program does not stop and */ /* never returns. We've used an endless */ PWM(); pulse(); } /* loop. You may wish to put in your own */ } /* code were we've printed the dots (...). */ /*==================================================================*/ /* PWM GENERATOR /*==================================================================*/ void PWM (void) { double pi=3.1416,rad2count; float m; int p,k; int f; p=400; f=50; m=0.9; //printf ("Masukan Modulation Index P\n"); //scanf("%d",&p); //printf ("Masukan Nisbah Pemodulatan m\n"); //scanf("%f",&m); PECC7_init=0x0400+(p/2); PECC6_init=0x0400+(p/2); period_reg=(500000/(f*p*0.05)); rad2count=(pi*f)/10000000; for (k=1;k<=p/2;k++){ deltaKLa[k] = period_reg-((pi/(2*p))+(m*pi/(2*p))*sin((pi*2*k)/p))/rad2count; deltaKLb[k] = period_reg-((pi/(2*p))+(m*pi/(2*p))*sin((pi*2*k)/p))/rad2count; //deltaKLa[k]=period_reg/2; //deltaKLb[k]=period_reg/2; //deltaKLa[k] = (pi/(2*p))+(m*pi/(2*p))*sin((pi*2*k)/p); //deltaKLb[k] = (pi/(2*p))-(m*pi/(2*p))*sin((pi*2*k)/p); //deltaKLa[k] = deltaKLa[k]/0.000016; //deltaKLb[k] = deltaKLb[k]/0.000016; if(deltaKLa[k]>=period_reg-100){ deltaKLa[k]=period_reg+1; } if(deltaKLb[k]>=period_reg-100){ deltaKLb[k]=period_reg+1; } printf("%d ",k); printf("La=%d ,Lb=%d \n",deltaKLa[k],deltaKLb[k] ); } PWM_Init(); PWM_PEC_init(); CC_PEC_init(); PWMCON0=PWMCON0+0x000F; /* PTR0=1;PTR1=1;PTR2=1,PTR3=1 RUN PWM CHANNEL 0,1 */ DP2=DP2+0x00007; /* Set P2.0,P2.1 as Output */ P2=P2+0x00007; /* P2.0,P2.1-->high, Enable Driver output */ while(1){ } } /***********************************/ /* Init Capture/Compare for PEC service */ /***********************************/ void CC_PEC_init(void){ CCM2=0x0020; /* ACC9=1; CCMOD9=0x2 ---> negetive edge; */ DP2=0x0000; /* SEt P2 as input */ EXICON=0x0002; /* Fast External Interrupt Enable */ CC9IC=0x007E; /* Capture ch9 for PEC priority level 15,group 2 */ } /************************************/ /* Init PWM module for PEC service */ /************************************/ void PWM_PEC_init(void) { PWMIC= 0x007F; /*Set PWM Interrupt priority level 15,groupt 3 */ PECC7=PECC7_init; /*Initialize PECC7 for PWM module */ SRCP7=(int)&deltaKLa[1]; DSTP7=(int)&PW0; PECC6=PECC6_init; SRCP6=(int)&deltaKLb[1]; DSTP6=(int)&PW1; } /***********************/ /* PWM Init / /***********************/ void PWM_Init(void){ PWMCON0=0x0100; /* PTx = CLK cpu ,ENABLE CHANNEL 0 INTERRUPT,*/ PWMCON1=0x003F; /* PWM CHANNEL 1,2 ENABLE IN MODE 1 */ DP7=0x000F; /* SET P7.0,P7.1,P7.2 as OUTPUT */ P7=0x0008; /* Inverted PWM. */ PT2=PT1=PT0=0x0000; PP1=PP0=period_reg; /* Pulse witdh period */ PP2=PP3=2*period_reg+1; PW0=deltaKLa[1]; PW1=deltaKLb[1]; PW2=PW3=period_reg; //PW2=period_reg/2; //PP2=period_reg; } /*==================================================================*/ /* PWM Interrupt /*==================================================================*/ void PWM_0 (void) interrupt 0x3F using S_RBANK { //PIR0=0; /* Clear Interrut request flag PWM channel 0 */ //PWMIR=0; PECC7=PECC7_init; SRCP7=(unsigned short)&deltaKLa[1]; //SRCP6=(unsigned short)&deltaKLb[1]; //PECC6=PECC6_init; } /*==================================================================*/ /*==================================================================*/ /*===================================================================*/ /* PULSE GENERATOR /*===================================================================*/ void pulse (void) { DP2=0xFFFF; ODP2=0x00FF; while(1){ P7= 0xFF; delay (20000); P7=0x00; delay (20000); } } /*===================================================================*/ /* Funtion delay /*===================================================================*/ void delay (int i) { while(i>0) { i=i-1; } } /*--------------------------------------------------------------------*/
