Dear Sir how to find the total xdata ocipied in the OBJ file at the time of linking or before . Is Any settings in the compiler please give me soultion for this regards girish
Look in the Map file generated by the Linker. BTW: No need to put your whole message in Italics!! ;-)
When you compile a C file, the compiler generates a .LST file. The following is included at the bottom:
MODULE INFORMATION: STATIC OVERLAYABLE CODE SIZE = 30 ---- CONSTANT SIZE = 10 ---- XDATA SIZE = ---- ---- PDATA SIZE = ---- ---- DATA SIZE = ---- 2 IDATA SIZE = ---- ---- BIT SIZE = ---- ---- END OF MODULE INFORMATION.
Jon, What with overlaying and everything, would it be correct to say that the total overall RAM (DATA, XDATA, etc) requirement of the final linked application may be less than the sum of the individual Object modules?
Andrew, what about if you build a library?
Yep
I dunno! Don't you get some sort of Linker listing for a library?
Thanx for your suggestion. It helps me. I have found the xdata occupied by the all files through .M51 file. It looks like this TYPE BASE LENGTH RELOCATION SEGMENT NAME ----------------------------------------------------- * * * * * * * D A T A M E M O R Y * * * * * * * REG 0000H 0008H ABSOLUTE REG 0008H 0008H ABSOLUTE DATA 0079H 0002H UNIT ?BANK?DATA DATA 007BH 0002H UNIT ?DT?DR_POWER DATA 007DH 0001H UNIT ?DT?DR_KEY DATA 007EH 0001H UNIT ?DT?PTML_VM DATA 007FH 0001H UNIT ?C?LIB_DATA IDATA 0080H 000DH UNIT _IDATA_GROUP_ IDATA 008DH 0008H UNIT ?ID?DR_IIC * * * * * * * X D A T A M E M O R Y * * * * * * * 0000H 0400H *** GAP *** XDATA 0400H 0063H INPAGE ?PD?GLOBC XDATA 0463H 01F2H UNIT ?XD?PTMI_VM XDATA 0655H 01B0H UNIT ?XD?PTMI_DSD XDATA 0805H 00EDH UNIT ?XD?XX_GLOBC XDATA 08F2H 00ADH UNIT ?XD?PT_HLMI XDATA 099FH 0089H UNIT ?XD?PTMM_VM XDATA 0A28H 0042H UNIT ?XD?DSAA XDATA 0A6AH 0041H UNIT ?XD?PMA_RMC XDATA 0AABH 002CH UNIT ?XD?DR_LCD * * * * * * * C O D E M E M O R Y * * * * * * * CODE 0000H 0003H ABSOLUTE CODE 0003H 0003H ABSOLUTE CODE 0006H 0004H UNIT :) girish
Do you know an equivalent method if you have assembly code ? I have not found anything useful in the assembler. And what happend if you only have the objs or a lib, any idea ? Thanks in advance Javier
