I have written a program read the converted Analog to digital signal and disply on 4 digit seven segment display indicator, by multiplexing . Alos I have multiplied the ADC out put by 2.78 and 0.02, to get a perfect scaling for the display I have attached code for reference. When I compiled this program , I am GETTING " IMPROPER FIXUP ERROR" please let me know if this( test= adc_input*.02*2.78; ) multiplication allowed. I think it is not a full floting point arithmetic Kindly help me resolve this. ****************************************************************************************
#include<reg51.h> #include<intrins.h> sbit unit= P2^0; /* unit data for sending through the port */ sbit tens= P2^1; /* Tens place for sending the data */ sbit hundred=P2^2; /* Hundred place for sending the data */ sbit thousand=P2^3; /* thousand place for sending the data */ sbit relay= P2^4; /* for relay */ sbit write = P2^5; //set to zero for write(p2.5) sbit read = P2^6; //set to zero for read (p2.6) unsigned int count; /*count to track 2 millisecond interrupt */ /* CODE FOR SEVEN SEGMENT DISPLAY */ unsigned char code table[]={0xBF,0x86,0xDB,0xCF,0xEC,0xED,0xFC,0x87,0xFF,0XE7}; unsigned char code lookup[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09}; unsigned char temp; /* TO increment the variable at every 2 seconds */ void sec_timer(void); /* Interrupt fnction for timer 0 */ void convert(void); /* interrupt function to read analog to digital output */ void _nop_(void); void display(void); float test; unsigned int t_first,t_second,new_test; unsigned int volatile adc_input; unsigned char first,second,third,fourth; unsigned char msb,msb_1,msb_2,msb_3; void main() { TMOD= 0x01; /* set the timer 0 to MODE 1 for 16 bit counting */ TH0= 0xF8; /* th=f8,tl=f8 */ TL0= 0x2F; temp=0; ET0=1; /* enable timer over flow interrupt */ IT0=0; /* Set the external interrupt INT0/ to low level triggered interrupt */ EX0=1; /* Enable the external interrupt INT0/ */ EA=1; /* Enable all the interrupt */ TR0=1; /* start the timer */ while(1) { write =0; //start conversion test= adc_input*.02*2.78; new_test =test*100; first = new_test /1000; t_first =new_test%1000; second = t_first/100; t_second= t_first%100; third = t_second/10; fourth = t_second%10; msb= lookup[first];//MSB, left most digit msb_1= lookup[second];//MSB-1 msb_2= lookup[third];//MSB -2 msb_3= lookup[fourth];//MSB-3 display(); //call to display routine. } } void display (void) { P0=table[msb]; unit=1; /* Send the data on PORT 0 for MSB0 LED */ _nop_(); unit=0; _nop_(); P0=table[msb_1]; tens=1; _nop_(); tens=0; _nop_(); P0=table[msb_2]; hundred=1; _nop_(); hundred=0; P0=table[msb_3]; thousand=1; _nop_(); thousand=0; } void convert(void)interrupt 0 using 2 { write=1; /* stop convertion */ read = 0; /* send the read pulse */ adc_input=P1; /* Read the ADC out put*/ read=1; /* disable the read switch,INT0 will go low following this*/ IE0= 0; /* clear the interrupt */ write =0; /*start convert */ } /* To generate the interrupt at interval of 2 milliseconds USING TIMER 0 IN MODE 1 */ /* USING 12MHz crystal,1 count - 1 microseconds . hence when "0xF82F' is loaded to */ /* the TH0 and TL0 Timer register ,will generate interrupt at every 2 millisecods */ void sec_timer(void)interrupt 1 using 1 { TR0=0; /* stop timer */ EA =0; /* Disable interupt */ TH0=0xF8;/* Reload timer to generate interrupt for every 2 milliseconds */ TL0=0x2F;/*Reload timer to generate interrupt for evert 2 milliseconds */ count=count-1; /* decrement counter fo revery 2 milliseconds */ EA=1;/* enable interrupt */ TR0=1; /* start timer */ }
Hello: Sorry I can't help you with the error you are getting. I just have a suggestion that may or may not help you with your application. How about replacing your floating point math with something like this.
(UWORD)(((ULONG)adc_input * 5693 + 512 ) >> 10 );
I compile & link without errors (Ver 6.20c / Ver 4.20). Are you using some special device, compiler, linking options?
There is a Knowledge Base article about this - use the 'Search' link in the ribbon at the top of the page.
