How can I read out at89s8252 EEPROM value while soft simulate?
In C51 Version 7.00 the DATA Flash of the AT89S8252 is fully simulated. Are you using this version?
Yes, I am using this version. How can I read out value?
It should work the same way as on the AT89S8252 target. If you cannot get it to work, please send me your example code along with your serial number to: support.intl@keil.com
