problem getting a simple app to work on a eprom sim.
hi,
I have a simple question concerning the demo version of uVision 2.
I wrote a simple test program in assembler which just switches an LED and it runs perfect with my target eprom.
I define a offset, so that nothing can be linked into the memory from 0x0 - 0x8000
	offset	equ	0x8000
	cseg at reset
	ds	offset
	cseg at reset+offset
	jmp	init_cpu
        ORG	offset+0x100
        program starts here...
Now I want to create an hex file, which should run on my eprom-simulator.
I thougt, I have to set offset to 0. Then I have some space for the vectors and the program starts at 0x100. But nothing happens. In the debugger it works fine, I have a LJMP at 0x0 to 0x100 and there the program starts, but on the eprom simulator nothing happens.
Where exactly do I have to start the program code in the demo version? I'm using a philips 80c552.
Thanks in advance,
Christian
  • The reset vector is fixed at 0x0000; it is defined by the CPU hardware - this is the 1st instruction your CPU will executa after a reset.
    Therefore your jmp init_cpu needs to be placed at 0x0000 - then you can locate the rest of your code wherever you like (within the restrictions of the demo version, of course!)
  • Therefore your jmp init_cpu needs to be placed at 0x0000
    done.
    What exactly are the restrictions of the demo version?
    The docs for the eval-version from keil say Programs start at offset 0x0800.
    Does that mean, that I have to set a jmp at 0x0 pointing at 0x800 and everything is fine (i.e. setting the OFFSET variable in my above example to 0x800)?
    I tried this and it did not work. The problem is, I'm not sure if my eprom simulator works, and before I buy another one I want to be sure.
    Christian
  • The problem is, I'm not sure if my eprom simulator works
    You may try it in the µVision2 simulator.
