What is the meaning of Volatile used in a variable declaration? Thank's Sergio
This is a 'C' question. Volatile tells the compiler/optimizer to not assume a variable will be the same from use to use. This stops the optimzer from loading a variable into a register and using the value there instead of re-reading the variable. It is used on any variable which may be changed in an ISR or a different thread/task in a multi-thread/task system. Best luck
memory-mapped IO variables would also need to be specified as volatile I think Keil C51 implicitly specifies volatile for SFRs?
I think Keil C51 implicitly specifies volatile for SFRs? Yep - That's correct. Jon
