Hello I, trials building up a remote debugging connection between Keil uvision 6.22 eval (C51) and Proteus 5.2 Lite. I get a error message as soon as I start the debugger in the uvision. VDM51 Failed to connect socket to localhost : 8051 GLE = 000274D how can I clear this? Operating system: xp and win98 thank you. S.Mueller
hey, men, i get the same problem. If you find out how to fix it, could you sent me a email and tell me how? thanks! also which version you're using? I have VSM unlocked version! if you want, i can sent it to you! thanks, Brant Zhang
Hi, We have provided instructions on configuring Proteus VSM to slave to the Keil IDE. The URL for this document is given below. http://www.labcenter.co.uk/support/vsm_and_keil.pdf You should also check the option in the Debug Menu within ISIS entitled Use Remote Debug Monitor. If you are still having problems or have any further questions please feel free to email us.
I have same problem at windows-2000 ( Proteus 5.20 SP7 DEMO & Keil 6.23 eval) I change port to 8000 and all work !! Val.
