Dual DPTR in the Debuger
Hi!
I use a T89C51CC01 from Atmel WM, I would like to use the dual dptr feature on my program. When I run the Debugger, i can't switch the DPTR.
In the µC manual, it says that we must set the DPS bit of the AUXR1 register. I do this just before writing on the DPTR. When i set this bit and write just after on the DPTR register, the debugger show me that i write on the first DPTR and not in the second ?
Does anyone konw why ?
save_table_eeprom:
MOV	A,EECON
ANL	A,#01H
CJNE	A,#00,save_table_eeprom ;Test si l'EEPROM n'est pas occupé
;Début de la programmation
MOV	EECON,#02H
ORL	AUXR,#020H
MOV	DPTR,#0081H
MOV	AUXR1,#01H
MOV	DPTR,#01C8H ;here it's my problem!
MOVX	@DPTR,A ;I rite on the bad DPTR
;Lancement du cycle d'écriture en EEPROM
MOV	EECON,#054H
MOV	EECON,#0A4H
RET
  • I haven't looked at this closely recently, but the debugger never used to show the 2nd DPTR for the Triscend E5, either!
    I think it displayed the "currently-selected" DPTR value - according to the DPS (DPTR Select) register.
    You should be able to view the actual value via the SFR address. I wrote a uVision Debug Function to do this.
    Both of the DPTR values were displayed in the simulator!
  • I didn't need to view the actual value by the SFR address! I need to know if i really use two or one DPTR in my program!
    Does the debugger could show me if my second DPTR is used ?
    In the debugger mode of µVision, It seem's to me that the register window show the value of the two DPTR normally!
    There is DPTR[0] and DPTR[1]. So, why DPTR[1] never change and keep the value 0x0000 ?
  • The support of the second DPTR is available since the 6.02 version of Keil C51. So, how to use it ?
    I search your knowledge base and i found it:
    http://www.keil.com/support/docs/1463.htm
    Is there something else who can help me to simulate correctly the second DPTR ?
  • C51 only ever uses the extra DPTR(s) in a limited set of library functions (memcpy, memmove, memcmp, strcpy, and strcmp), and you have to specifically enable that usage with a command-line option (or 'Use Multiple DPTR Registers' in the uVision Target Options).
    See the manual.
    You won't find C51 using multiple DPTRs in your own application code.
