Is anybody try to debug assembler code with MPL macros. In the source window, line in file is not correct adress instructions. I sent 2 email to Keil about three weeks and I haven't any answer. Also, did you try to use standard macros and MPL macros in the same file. There is nothing in documentation that tell is not possible, but standard macros are not expanded. Finally, I don't understand why it is not possible to use C macros for common header files with MPL macros. It seems that implementation of MPL macros is not really operational. I use A51 V6.20g, the third version that Keil sent to me to try to correct problems.
