Hello All, I'm using UV2 with the cygnal emulator. After downloading and running the code, there seems to be no way to restart the code without having to exit debug mode and download the code again! I've wired up a reset button but reset seems to be ignored during debug mode. Am I missing something obvious here. This seems like an important feature. Thanks, Don
Peripherals/Reset CPU (also on the Debug Toolbar) - works fine with the Triscend E5.
YES, reset button on the target doesn't work while debugging. It does work if you cycle power, the application starts running and you can use the reset button. Also when I press the menu button PERIPHERALS/Reset CPU will cause everything to hang. Maybe CYGNAL will have a new driver soon http://www.cygnal.com
Must be a Cygnal-specific problem - it works with Triscend!
