I'd like to measure how many instructions occur between successive visits to the same breakpoint. What is the easiest way to do this in uV2?
Now that I've used uVision2 a bit more, I'll be more specific: I see the states and sec when I'm running the simulator. They're not present when I'm running the Cygnal F005 DK with their plug-in for uV2. What I'd like to be able to do are: 1) get timing information when running real target hardware, not just in the simulator, and 2) be able to reset states and sec so that I can deduce the elapsed time without doing any math. Regards
To get this sort of information, you need a real ICE - this is one of the few points where things like the Cygnal on-chip JTAG debug fall short of a real ICE. I have the same limitation using the on-chip JTAG debug of the Triscend E5. Refer to the section "µVision2 Restrictions when using Monitor-51" in the uVision Getting Started Guide - the same restrictions apply here Perhaps Keil could make these notes more generic in the next revision?
Ahhh ... that makes sense. Thanks for your prompt reply -- over the weekend, no less! Regards,
