How can I add databookt to the "Device Data Books" in uVision2? Thank you ...Leo
Try device database editor (Menu:File->Device Database) Regards, Mike
Nothing to do with the Device Database! Go to the 'Books' tab, and double-click the entry 'Add on databooks' This will open the Keil document, "Add Books to µVision2 Project Window – Books Tab" - which tells you how to do it! Note that the 'Book Path' is not limited to just PDF files - it can be any type of file that your system knows how to open: URLs, MS-Word docs, etc, etc, etc.
The approach with the Device Database works though :-) Only to see the changes in the database one needs to reselect device for target.
