Is it possible to access particular bit in xdata memory space without changig other bits' values (eg using ^).
There is no hardware bit twiddling to the xdata memory space. So you have to do read/modify/write instructions.
char xdata Var; Var |= 0x01; // set bit 0 Var &= ~0x01; // clr bit 0 Var ^= 0x01; // chg bit 0
