C51 'in-line' compilation
Hi!
I've a particular module within a large project in which I wish to avoid making jumps to code segments from other modules (including C51 library code).
Is there a means by which I can ensure that the compilation of this module will expand any calls to external code segments 'in-line'? I guess this is more-or-less what happens when optimising for speed, but would appreciate any feedback. (i.e is there a #pragma directive for speed?)
Thanks!
David
  • Yes, C51 provides you with the OPTIMIZE (SPEED) directive.
  • but this does not mean that it will make function calls inline.
    C51 does not have a #pragma inline.
    In particular, note that the manual is incorrect when it says that the intrinsic functions are inserted inline: this is not true - they are called just like any other function.
  • In particular, note that the manual is incorrect when it says that the intrinsic functions are inserted inline: this is not true - they are called just like any other function.
    This is only true for the _chkfloat_, _lrol_, and _lror_ functions.
    The _crol_, _cror_, _irol_, _iror_, _nop_, and _testbit_ routines are implemented as explicit instructions. For example:
    ;---- Variable 'i?042' assigned to Register 'R2/R3' ----
    ;---- Variable 'c?041' assigned to Register 'R1' ----
    			; SOURCE LINE # 6
    ; float f;
    ; unsigned char c;
    ; unsigned int i;
    ; unsigned long l;
    ; bit b;
    ; if (_chkfloat_ (f))
    			; SOURCE LINE # 14
    	MOV  	R7,f?040+03H
    	MOV  	R6,f?040+02H
    	MOV  	R5,f?040+01H
    	MOV  	R4,f?040
    	LCALL	?C?CHKFLOAT
    	JZ   	?C0001
    			; SOURCE LINE # 15
    ;   f = 0.0;
    			; SOURCE LINE # 16
    	CLR  	A
    	MOV  	f?040+03H,A
    	MOV  	f?040+02H,A
    	MOV  	f?040+01H,A
    	MOV  	f?040,A
    			; SOURCE LINE # 17
    ?C0001:
    ; c = _crol_ (c, 3);
    			; SOURCE LINE # 19
    	MOV  	R0,#03H
    	MOV  	R7,AR1
    	MOV  	A,R7
    	INC  	R0
    	SJMP 	?C0007
    ?C0006:
    	RL   	A
    ?C0007:
    	DJNZ 	R0,?C0006
    	MOV  	R1,A
    ; c = _cror_ (c, 4);
    			; SOURCE LINE # 20
    	MOV  	R0,#04H
    	MOV  	R7,A
    	INC  	R0
    	SJMP 	?C0009
    ?C0008:
    	RR   	A
    ?C0009:
    	DJNZ 	R0,?C0008
    	MOV  	R1,A
    ; i = _irol_ (i, 3);
    			; SOURCE LINE # 22
    	MOV  	R0,#03H
    	MOV  	R7,AR3
    	MOV  	R6,AR2
    	MOV  	A,R7
    	INC  	R0
    	SJMP 	?C0011
    ?C0010:
    	RLC  	A
    	XCH  	A,R6
    	RLC  	A
    	XCH  	A,R6
    	MOV  	ACC.0,C
    ?C0011:
    	DJNZ 	R0,?C0010
    	MOV  	R2,AR6
    	MOV  	R3,A
    ; i = _iror_ (i, 4);
    			; SOURCE LINE # 23
    	MOV  	R0,#04H
    	MOV  	R7,A
    	INC  	R0
    	SJMP 	?C0013
    ?C0012:
    	MOV  	C,ACC.0
    	XCH  	A,R6
    	RRC  	A
    	XCH  	A,R6
    	RRC  	A
    ?C0013:
    	DJNZ 	R0,?C0012
    	MOV  	R2,AR6
    	MOV  	R3,A
    ; l = _lrol_ (l, 3);
    			; SOURCE LINE # 25
    	MOV  	R7,l?043+03H
    	MOV  	R6,l?043+02H
    	MOV  	R5,l?043+01H
    	MOV  	R4,l?043
    	MOV  	R0,#03H
    	LCALL	?C?LROL
    	MOV  	l?043+03H,R7
    	MOV  	l?043+02H,R6
    	MOV  	l?043+01H,R5
    	MOV  	l?043,R4
    ; l = _lror_ (l, 4);
    			; SOURCE LINE # 26
    	MOV  	R0,#04H
    	LCALL	?C?LROR
    	MOV  	l?043+03H,R7
    	MOV  	l?043+02H,R6
    	MOV  	l?043+01H,R5
    	MOV  	l?043,R4
    ; _nop_ ();
    			; SOURCE LINE # 28
    	NOP
    ; if (_testbit_ (b))
    			; SOURCE LINE # 30
    	JBC  	b?044,?C0015
    	SJMP 	?C0003
    ?C0015:
    			; SOURCE LINE # 31
    ;   b = 1;
    			; SOURCE LINE # 32
    	SETB 	b?044
    			; SOURCE LINE # 33
    ?C0003:
    ; while (1);
    			; SOURCE LINE # 35
    	SJMP 	?C0003
    ; END OF main
    Jon
  • Okay. The lib. functions that my 'c' module require are LSTIDATA ,LLDIDATA and similar, they aren't inlined when the CODE(SPEED) option is specified. I guess my only means of inlining these is to do it manually.
    Thanks for your comments.
    David
  • This is only true for the _chkfloat_, _lrol_, and _lror_ functions.
    Guess which ones I was using, then... ;-)
    When will the manual be corrected?
  • Those routines are helper routines and they are not included inline. Refer to
    http://www.keil.com/support/docs/1964.htm
    for a little more information about what the routines do and how to "decode" the function names.
    Jon
