Hi, Having wondered why the linker couldn't locate a code segment which I'd specified as part of the BL51 command line, I took a look at listing file to discover that the compiler had (somewhat arbitrarily) appended an underscore to some of the function names, hence the link error. Is there a means of inhibiting (or predicting)this annoying compiler characteristic? Thanks!
Well, the first port of call for all such questions is always the Compiler manual! ;-) You didn't say which toolset - I assume we're talking C51? When you say "append" I assume you mean "prefix?" The compiler adds various prefixes depending on whether & how parameters are passed. See the "Segment Naming Conventions" section in the manual The error probably means that you've mismatched your function prototypes & definitions. What exactly is the error you get? What does it tell you if you look up the error in the help?
A function name has an underscore prepended if the function has any parameters. No parameters, no underscore. Goodness knows why...
A function name has an underscore prepended if the function has any parameters. No parameters, no underscore. Goodness knows why... This is incorrect. In the compiler manual, there is a section named "Segment Naming Conventions". In that section, is a sub-section named, "Program Objects". Under "Program Objects", there is a table that discusses the naming conventions for functions. A segment with an _ prefix indicates that arguments for that function are passed in registers. If you do not want your arguments to be passed in registers, use the NOREGPARMS directive. Jon
